Does anyone know where to find a list of serial numbers or know what the build dates are from the serial number. I just acquired a model 111. It has a few issues not too bad though cross feed doesn't work but the others do it is kind of weird every position on the pull knob on the apron engages the carage. The other two issues are mostly cosmetic meaning not a big deal, missing bottom clamp for the clamp on the taper attachment and thr spring knob is broken on the change gears that locks the pin in. I have a lot of cleaning to do but it seems to be a pretty decent little machine.
