In both longitudinal and cross-feed my clutch will disengage after a few secs when under moderate to heavy load, unless I tighten the start knob about as much as I can by hand. I re/re'd and cleaned the apron a few months ago and all parts looked unworn and it has remained clean. It doesn't engage until the star wheel is turned almost all the way in and I can make it slip by holding the cross feed or handcrank wheel unless it is very tight. Oil sump is full. Any ideas?
Here are some pics of the same clutch on a clone:
http://steammachine.com/hercus/page5.html
Also, if anyone has the dimensions of those two 1/2 circle discs I would appreciate it.
