I have a imservice 12x12 router with servo motors I need to replace the control box and software with something more user friendly the machine is sturdy and tight any suggestions will help. Mostly all I do is engraving like clock faces.
Just FYI, I use Mach3 on a modern Windows 10 computer and use Ethernet to talk to the Smoothstepper controller.
+1 here as well. I've used the USB smoothstepper, ethernet smoothstepper, and the UC100 controller. All work perfectly with mach3Same here. Very stable operation and you can easily use a laptop for this purpose. I run high performace AC servos @ 3MHz step rates without issues
