- Nov 24, 2013
- 257
I had to cut the 25 feet long hose in my old portable air compressor because I have no need any more for such a long hose.
Now I have a 5 feet long hose from my compressor and at the end I use the fitting I need which I secure it with this screw clamps we use for water hoses, I think they are called Breeze clamps (you tightened the screw to close the clamp).
I know this clamp is not as per codes but have you used it for similar purposes and does it hold? The pressure in my compressor is about 110PSI
