- Feb 2, 2013
- Location
- Ethereal Plane
Hello again!
i've been working out production of some custom shoulder bushings ,in delrin , for some conveyor systems i service.
i'll be making about a thousand bushings when it's all said and done, primarily in 4 outside diameters (.376",.438",.501",.626") but, thankfully all sharing the same inside diameter of .257".
sounds fair enough , but, here's the kicker- i'm only allowed about .110+/-.001" for the shoulder of the bushing.
that's not a lot of meat to grab ahold of...
i found previous attempt at a production run to go smoothly. i constructed bushings from spacers i had made for another job and repurposed them for this run to make sure the machine was set up as if i were to start running it for real.
i got about 10 bushings into the run before i saw an irritating hurdle, the bushing wants to spring and can easily dislodge from the 5c collet.
as you can see, the final dimension was too thick (.126") in the shoulder from a mock production run.
i have to be at .110" or so.
i needed a custom 5C collet stop that offered a little more support....
EUREKA!!!!!
Here's a shot of the working model as used!
it wasn't very hard to produce....
i had a commercially made collet stop that had a nice tool steel stud that didn't want to cut well.
so rather than completely messing it up i decided to get something softer to work with.
at the local hardware store they had 3' lengths of 1/2-20 all thread.
it cuts like butter and can clean up nice if you leave a little radius on the tool tip, i had a sharp tool and used the Hercus' auto feed to knock some threads off for grip clearance inside the 5C.
then i turned down the nose to .256" to a depth of .250" as a nice mandrel for the last order of operation.
here's the parts right before assembly and adjustment.
the bushing lower left was commercially made, i provided the 1/2-20 nut and a 5" section of all thread.
the collet stop worked like a charm and i was able to achieve .110" shoulders on 100 bushings in this run!
thanks for reading!
if you have other ways of skinning this cat, i'd love to hear them!
EUREKA!!!!!
thanks for reading!
