T
Tom Griffin
Forum Guest
Register Today
When I was building my Chevelle, I wanted to mount all of the accessories as low as possible on the engine to give the engine compartment a cleaner look. The commercial varieties were either too expensive or not quite what I was looking for so I decided to make my own. The arms are just plate aluminum sawed and belt sanded to size from cardboard templates. They attach to existing tapped holes in the heads with turned aluminum spacers and bolts. The adjustment is just a couple of rod end bearings (right and left hand) connected by a turned aluminum nut. The whole setup was then blended and buffed to give it a nice appearance. I have a lot of miles on the set-up and have had zero issues with it. It's a nice rigid and easy to adjust design. I also made the water pump and crankshaft pulleys just for fun, and a matching set of power steering brackets.
Tom
![116_1611.JPG 116_1611.JPG](https://www.hobby-machinist.com/data/attachments/105/105562-a2a343b90901b6f66e0fd161a64014fb.jpg)
![116_1612.JPG 116_1612.JPG](https://www.hobby-machinist.com/data/attachments/105/105565-de71b0552c90fe5c127b39542cc1f564.jpg)
![116_1614.JPG 116_1614.JPG](https://www.hobby-machinist.com/data/attachments/105/105568-3ade9d551b3be0b5235d16a8bfb1c3b6.jpg)
![116_1611.JPG 116_1611.JPG](https://www.hobby-machinist.com/data/attachments/105/105560-a2a343b90901b6f66e0fd161a64014fb.jpg)
![116_1611.JPG 116_1611.JPG](https://www.hobby-machinist.com/data/attachments/105/105561-a2a343b90901b6f66e0fd161a64014fb.jpg)
![116_1612.JPG 116_1612.JPG](https://www.hobby-machinist.com/data/attachments/105/105563-de71b0552c90fe5c127b39542cc1f564.jpg)
![116_1612.JPG 116_1612.JPG](https://www.hobby-machinist.com/data/attachments/105/105564-de71b0552c90fe5c127b39542cc1f564.jpg)
![116_1614.JPG 116_1614.JPG](https://www.hobby-machinist.com/data/attachments/105/105566-3ade9d551b3be0b5235d16a8bfb1c3b6.jpg)
![116_1614.JPG 116_1614.JPG](https://www.hobby-machinist.com/data/attachments/105/105567-3ade9d551b3be0b5235d16a8bfb1c3b6.jpg)
Tom
