- Jan 9, 2013
- 1,020
Real lathe newbie here, who has probably a dumb question, but …OK, so how do I explain this. I’m starting out with a piece of 1/2” x 7” x 7” aluminum plate that I was going to bolt through it’s center to a 1” rod that will be mounted in the chuck of my 10 x 22 Grizzly lathe.
I need to end up with a ring 5.5” od x 4.5” id x 1/2” thick from this plate. What type of tool should I use to plunge into the face of the plate that will cut all the way through without hanging up on the walls of the (circular) groove that will eventually go all the way through the plate.
Or is this not the way to go about it? I want to save the center 4”+ disk for another smaller ring.
