Cutting tool for huge lathe?
JRT
H-M Supporter - Gold Member
Oct 2, 2018
132
Is this for a huge lathe?
That does makes sense. Hopefully someone will recognize what it is used for. Thanks.
This is a 3/4" square deep hole threading bar.
  • Like
Reactions: JRT
Thanks, I wonder if I could use it on a small lathe to turn down aluminum and brass without issue? Obviously the stick-out would be very short, not even an inch.
I would probably use a normal size HSS tool for that.
I seem to remember This Old Tony using long tools like that when he had his shaper. Longer needed to get from the clapper box to the work.
  • Like
Reactions: JRT
Tool length depends on the complexity ( shape ) of the part being machined . Sometimes very long tools are needed to bypass obstacles such as boring behind shoulders on very large lathes . Most of the time these are shop made tools as they are custom tooling job specific . I have a lot of these types of tools from over the years . As far as you using it , sure . You won't be hanging it out but you'll need a CXA 3/4" holder at least.
