- Mar 22, 2022
- 346
So far in my rather rudimentary checking I have not seen anything that points towards bigger problems. Everything fits tight, no odd wear on the ways.What I see is mainly aesthetics. Those issues should have nothing to do with function. However things could have happen during the crashes. Low probability in my opinion.
Is there excess play in the compound and cross slide? I have 1 lathe that has .060 backlash. It is very repeatable in accuracy. ( I do have the replacement nut) no real excuse not to replace
some play can be removed by gib adjustment. Highly recommend this be done anyway.
Is the surface flat and clean where the tool post goes. This is a big must. Check that. If not flat make it flat. If you have a mill or access to one it will be a simple op. If not then draw filing flat will do also. Just more time consuming.
Check to see if the cross and compound lead screws are not bent. Do that by just dialing full travel. Should be same feel all the way. Ming you if you have the gibs adjusted snugly. It most likely will get more resistance on the end travel. Way less wear on those sections.
My suggestion would be. Take apart and inspect and clean one component at a time. Compound then cross-slide. Then fire it up and make some chips. Actually working on the machine will tell you what needs addressed if anything.
Have fun is the main thing.
Cutting oil is my blood.
you can see the weld on the outer edge of the tool post way below. That corner is slightly low but the rest is flat a s far as I see.
Haven't checked if the cross compound screw is straight, good idea. shows little wear and fit with the nut is even from end to end.
All the gib screws were loose and one was broken, uses flat gibs and they appear to be in good condition.
Following the advice to keep the work confined to a single group of items. Will get this all addressed then move on to the apron next.
Thanks for chiming in and for the advice!
