- Mar 20, 2014
- 440
better than the three tap set is to use a gun tap also known as a spiral fluted tap a much better tap great for thru holes the chip flows out the open hole and clears itself
I agree with what you said bfd, except for the name . You referred to the gun tap as a spiral flute tap , it is actually a SPIRAL POINT TAP that pushes the chips ahead, and out the through hole. The spiral flute tap pulls the chips up and out of the hole much like a drill bit. Hope I explained this OK, JR49
