[4]
Digital Caliper Issue
[10] Like what you see?
speedre9
Active Member
Aug 26, 2013
167
Likes
5
#1
Got me a Mititoyo 6 " caliper way back when. I have changed out the battery several times without issue. This time when I changed the battery when I turn it on I get a negative measurement of -1.1280". If I zero it out and press the abs button it sets to zero. When I shut it off and restart it I get the same thing, oh and once in a while it will bounce around between -1.128 to 0.0050. What do you guys think, is it fried or what. I don't know.
bill stupak
Active Member
Active Member
Feb 26, 2014
61
Likes
77
#2
I have a 6" Mitu that goes a little wonky about once a year. I usually take it apart and clean with denatured alcohol and it always fixes it. I did read somewhere that you could buy new internals for them though. Bill
speedre9
Active Member
Aug 26, 2013
167
Likes
5
#5
According to the Mitutoyo site the reading unit is shot, not only shot but obsolete and no longer available.
Luckily I bought a 12.00" digital Shars unit to replace it. I no longer need the super accuracy of the Mitutoyo brand
Thanks for the comments guys
ARKnack
Active Member
Active Member
Dec 19, 2014
161
Likes
85
#6
Myself, I never turn off my Mitutoio caliper. I've seen several articles that battery consumption does not change on or off. Which makes since because LCD displays draw negligible power and the electronics are always on to keep the absolute reading value.
One other thing is to use Silver Oxide batteries. Not alkaline batteries. Much longer life. It's been several years since I've changed my battery.
Wreck™Wreck
H-M Supporter-Premium Member
Sep 29, 2014
1,950
Likes
1,528
#7
I have 2 Digital Mits calipers, now I work in a coolant rich environment which plays hell with the non IP65 tools so use only dial calipers now.
They work fine again after they dry out, as noted above the batteries last me a year or more and I use them every day just not inside the machine enclosures where the coolant drips from the top like rain (-:
FOMOGO
Sep 2, 2013
1,477
Likes
1,198
#8
Mine gets used a lot, and I've never had any issues (knock wood). Still waiting for the original battery to die after 15yrs or so. I clean it well 1-2 a year. Have a HF ir temp gun that has the orig. battery. I swear I've had that thing for 20yrs. Now flashlights, not so much. Mike
Groundhog
H-M Supporter - Premium Member
Jan 20, 2016
540
Likes
628
#9
Update on the reset video above. I have a Mitutoyo SC-6" P caliper that would always start out at 0.001" until I reset zero, which was a tempory reset. It never seemed to matter how long I held the Zero button it always restarted at 0.001". Finally I read somewhere that you really need to use a paperclip to hold the "Zero" button down (after removing and reinserting the battery). There must be a second level for the Zero button that a paperclip reaches and your finger does not. My caliper has been reset to start out at 0.000" since I used the paper clip!
Boswell
Hobby Machinist since 2010
Feb 27, 2014
395
Likes
115
#10
I have several Mitutoyo Calipers that are all Solar powered. They have been working perfectly and I never need to find a battery. I just with my other battery powered tools could incorporate solar panels
EmilioG
Jul 20, 2014
1,044
Likes
388
#11
I had some issues with my 8"digital Mitutoyo until I demagnetized it. All is well now.
Same battery for two years now. I will remove the battery for storage though.
Uglydog
Dec 6, 2012
2,243
Likes
1,253
#12
Sorry,
I like my verniers.
Yep, sometimes I gotta squint.
But, they always work.
Daryl
MN
[6]
[5] [7]
