I'm not scared of making a good plate. I won't divide that. I will drill a hole where the dro says to 127 times. I played with hole size, hole spacing, and circumference. Im pretty sure I can get it on a standard size plate. I am curious what method of indexing when I cut the gear will be more accurate. Do you think direct indexing without the gear train (plate mounted to rotable face) will be any less (or more) accurate than simple indexing with the gear train in tact (plate mounted to dividing set up)? tcarrington, what do you mean about 50 something hole plates?
