I love my new vertex bs-0 dividing head. It opened up a whole new world of possibilities for me. I know this has probably been posted a gazillion times,but I feel like sharing.
Today I made myself a dovetail cutter using two
TCMT 16T308 MP NC 3225 inserts with a positive rake and 7degree relief angle.
I did not take enough pics for this post.....was enjoying myself too much.
What you don't see is, I've set my dividing head 30degr. out of parallel to my mill bed to get the right angle for the insert and tilt the DH 2degrees down to get a positive axial rake. I didn't want to go too big on that angle because of the 7 degr.
relief angle,I do not want the insert to drag.
The DH allowed me to machine the two insert landings at the same hight and depth 180 degrees appart.
The cutter angle is 60degr. and the shaft diameter is 20mm (the bigger the better.) The head is about 38mm OD and shaft about 75mm long.
I do not have a job for it yet and are eager to try it out. Maby I wil make a trial cut soon just to see if it works right. Thanks for reading guys.
