- Nov 8, 2012
Found this on another part of Yuriy's site at: http://www.yuriystoys.com/2012/01/reading-gtizzly-igaging-scales-with.html
testAugust 3, 2014 at 9:14 PM
Is the ANdroid DRO compatible with the serial output of the new igaging "ABSOLUTE" series ? : http://www.igagingstore.com/38-Absolute-Digital-Readout-DRO-Stainless-Steel-S-p/205483.htm
Reply
Replies
Yuriy KrushelnytskiyAugust 3, 2014 at 9:45 PM
I don't know; haven't had a chance to play with the new model.
Nathan WrightNovember 18, 2014 at 10:07 PM
Short answer: no.
At a minimum, the Absolute DRO has a 2KHz clock. But, changing the clock freq isn't enough.
The data line is severely attenuated with a 5.6K PD resistor. The original display unit has a 100K PU resistor, so this will require a schematic change to match.
Have not had a chance to look at the data on the logic analyzer to confirm if it is still 21-bit.
(There also appears to be a pull up on pin 4 of the Mini-USB. Looks to be a basic connection check - the control unit stops sending the clock if that pull up is removed. Looks like this can be ignored.)
Will investigate further and post an update as time permits.
Reply
Replies
Short answer: no.
