- Oct 5, 2010
- 1,044
I have a Clausing drill press with a 2 speed 3 phase motor. On the press is a 2 speed drum switch. Everything works well on the drill press, but I have a constant problem with it tripping the TECO phase converter and giving me an “OC-C” error. This only occurs when I use low speed, never on high speed. It will run in low speed but often when I switch to OFF I will get the error. The phase converter is remoted, so it is becoming a PIA. I have to go to the phase converter, turn the phase converter completely off to reset it or I have to turn the remote on/off switch to the Off position and return to the P/C and push reset to reset the phase converter.
I presume that it is something in the drum switch, because it happens less often when I switch to OFF very quickly. The slower I switch to OFF the more it trips the phase converter.
Any suggestions as to how I can fix the problem?
TIA
Randy
TIA
Randy
