- Jan 4, 2021
- 2,019
Strongly recommend the SS Absolute Plus (I don't think they are making the ones in your link anymore; probably NOS); you'll need a 6" & 12":This thread is good timing for me. Just in the past few days I have been researching DROs for my 7X16 Micro Mark. As most things I always try to t]do good, not the best, but on the cheap. I had been considering the iGaging EZ-View Dro. This set I found on feabay https://www.ebay.com/itm/142017292063?_trkparms=amclksrc=ITM&aid=1110013&algo=HOMESPLICE.SIMRXI&ao=1&asc=20211209162615&meid=9de51680fb42411ba2811243c35fb6a3&pid=101479&rk=1&rkt=12&sd=353847796660&itm=142017292063&pmt=1&noa=0&pg=4429259&algv=SimRWIWebRoundRobinBlenderWithPromotedSeeds&brand=iGAGING&_trksid=p4429259.c101479.m3476&amdata=cksum:1420172920639de51680fb42411ba2811243c35fb6a3|enc:AQAIAAABEKXWuUGeWZNDwRHZ2wLkfSP6eO0HvvoaL1McJo5mxBH%2BT9fwbenIEU%2BSOcnyNNYMYdrY6Pd3Xvh8JwIVgYQBoACshfZsw2EUEocPKTFIeFJYIhjiho7dtT5p%2BuLadOYXrinVsncBo5dPshS4VkPc8N9WxQBmM9mjsicqWQIFZVGZ6Uz4f3jEVoJFG%2FvyyOVyxrQfXgW9W0yDgoSSzHuoOtPppegbIp561qNWQjWfF8bM682YZCFeiAVl2%2FFbudkeGD3bD9HGM0L43B7lPdDd%2BN1e0MWkiE74HorKkJzMKca2CadEVOHFg5UnRQ05Ryk4g4BqEUsMCjW5XvEjxqsi1SoIAJuU6B1R1DVc%2FQweXfyV|ampidL_CLK|clp:4429259&epid=664564386
Now after the above reading comments I'm rethinking this may be a mistake? I only use it for hobby work a couple times a month. Would this be good enough or will it present too many issues and I should just consider a higher grade model?
Also was wondering if the iGaging system will work with the AC power adapter only,.. Without batteries?
![6in SS Absolute Plus.png 6in SS Absolute Plus.png](https://www.hobby-machinist.com/data/attachments/422/422907-d2aaa56c09a37fb584959eddcecdcc4f.jpg)
![12in SS Absolute Plus.png 12in SS Absolute Plus.png](https://www.hobby-machinist.com/data/attachments/422/422908-1eb4c4a4cde8214d25d09a916923455e.jpg)
You can stack the readouts:
![Stacked Readouts.png Stacked Readouts.png](https://www.hobby-machinist.com/data/attachments/422/422909-8898efd88b4c072920197d91e70338da.jpg)
Yes, the scales & readout will work from the AC Adapter only (but you may want to keep a set of batteries installed just in case you lose power so you don't also lose position. And you're better off getting the iGaging adapters rather than no-name ones.
You should also consider getting the TouchDRO Adapter (@ycroosh – I'm going to start wanting a commission): while you do get an incremental selection and metric/Imperial/Fractional Inches with the iGaging readouts, you'll be missing a lot of features.
