- Nov 25, 2015
- Location
- NJ USA
that's a error waiting to happen, and very annoying to have to change back and forth.Have a DRO on my mill, so it doesn't matter to me, DRO reads both and will switch from one system to another.
So maybe I need to make one in imperial sizes, and lap the mating surface.
When you look at the offerings, they seem to indicate that the tip is 4mm, and the next largest diameter is .2" but that's not possible given the picture. 4mm is .157 and that does not look 43 thou larger. On other pics it appears to also be 10mm as is the holding shank.
The largest diameter appears to be 18mm or .7086" considerably more than .5" that I can fit. I would consider making one 3/4"
The big question is what material, and what spring to use.
