- Nov 14, 2016
- 3,009
I'm wondering if penetrating oil was used prior to disassembly, O2 under pressure reacts violently with oil.
That seems likely. Instructions with O2 tanks and regulators are pretty emphatic about not using lubricating oils in the parts or to seal connections, so using WD40 or similar to get the stem off seems an equally bad idea.
I'm kind of baffled, he was trying to remove the valve while the cylinder still had pressure in it?
The valve wrenches for these are usually brass, plastic or zinc alloy presumably for their non sparking nature, so a standard steel adjustable wrench probably didn't do him any favors.
Cylinders are stored energy, even compressed air can do a lot of damage. I was a Self Contained Breathing Apparatus (SCBA) tech for several years, and I remember one of the instructors telling us about showing up at a fire station to certify the testing equipment just as somebody knocked over an air pack cylinder breaking off the neck. He said that cylinder went through an interior cinder block wall, sailed across the apparatus bay in front of him and exited the building through an exterior cinder block wall. In that particular incident he said through luck there were no injuries but many had to change their pants.
