Gallmeyer & Livingston model 20 Surface Grinder Manual
B2
H-M Lifetime Diamond Member
Sep 2, 2018
860
Hi Folks,
I maybe getting an old, but what looks like a very good condition Gallmeyer & Livingston model 20 Surface Grinder.
(6 x 18") table with magnetic chuck.
Should I?
Anyone have a manual.
The best I can tell this is a machine that was made around 1970. It is all cast iron, one piece, big, and weights in at about 2000#. The motor looks like new, but has a '93 written on it. So I assume it was a replacement. Also, it was pulled from a working shop years ago and never used since then. No obvious rust. All three axes handles rotate smoothly. I failed to check the spindle which may have been a big mistake on my part.
Any information would be appreciated. I could not find much on the web.
I ran a larger G and L surface grinder back in the 80s . Nice machine but we gravitated to the Okamotos and Brown and Sharps only because they were newer . Never had issues with the G & L though . Big machine , maybe 12" x 36" table .
  • Like
Reactions: B2
The spindle bearings should be examined for noise/roughness, maybe end play, if not good, may be expensive to fix.
Good machine! Ran one in the late ‘70s. As stated, spindle bearings can be an issue.
  • Like
Reactions: B2
Thanks Guys. Can one find parts if the spindle or its bears are worn?
