Hi all.... I am cutting a 20 tooth 32DP gear for the Hoglet engine. After cutting and looking at it I noticed that the tooth profile didn't look quite right. The top lands were way too narrow and on the first gear I cut the teeth basically came to a point. I've checked and re-check my setup and am satisfied that it is fine. Then I figured I had taken too deep of a cut, which according to the math should be .0704 (using 2.2/P +.002). I double checked the depth of cut with a dial indicator to compare with what the DRO said and they agreed with one another.
On the second gear I made a .068 depth of cut and the tooth profile still did not look correct....I made measurements of wires and appeared to be about .002 too deep still. So, I'm not sure what the problem is...
On the cutter there is a number printed, .1197. which I'm not sure what if anything it refers to.
I have attached photos of the cutter and the second gear for your viewing pleasure.
I'd like to hear your ideas and/or opinions. Thanks
