- Feb 7, 2013
- 2,493
Cathead, not following the use of dividing plates on RT. My table is Yuasa and does not have provision for dividing plates. The angle for the 15 tooth is 24 degrees which is super easy. The 35 tooth is 10.28571428571429 degrees and next to impossible to dial in.
Lo-Fi, thanks for the offer. I just might take you up on that if it proves impractical for me to try to make them. are you in The US? I'll PM you if I go that route.
[/QUOTE]
You take off the crank wheel and bolt on a dividing plate to the RT. Then add the dividing plate, spacer apparatus and the crank.
The mounting holes are under the hole spacer thing and crank handle on about a 2 inch bole circle(at least on mine).
I see the hole dog is missing on this photo. This plate is home made. Usually an RT will be supplied with 2 discs with
holes on both sides allowing to make most any gear count. You may not have the dividing plates and hole dog thing but I'm pretty
sure they are available. Take off your crank wheel and see if there are threaded holes to bolt on the disc. I have seen discs that
have 3 holes but mine happens to have 4 holes so it could be either I suppose.
The hole dog is simply a pointed pin that fits into the holes and has a spring loaded feature on it. It's not too hard to figure out
which set of holes to use. Each 360 degrees of rotation on a 90 to 1 RT is 4 degrees. Divide 360 degrees by the tooth count to
get the degrees to rotate for each tooth space. There is a chart to easily know which plate to use. A 49 hole plate will allow one to
make the 35 tooth gear. That would be two full rotations plus 28 holes on the 49 tooth plate.
Looking on E-Bay, the Grizzly brand RT looks to be Yuasa so That might work for you once you see what is under that crank wheel...
[/QUOTE]
