- Aug 4, 2015
- 291
OK, if you are looking for at a generator, I assume that you don't already have one. So why not get a 3 phase generator and skip the rotary phase converter all together? IF the generator is 208 3 phase, each phase to ground/neutral is 120 volts so you have your 120 power source covered. And depending on the generator some can be wired 240 3 phase. These are typically 12 wire generators and can by wired in any configuration up to 480. But unless you have equipment that is specifically 240 volts, then I would skip the rotary converter all together, get a 3 phase generator and be done with it.
