- Nov 6, 2018
- 24
So, about fifteen years ago I built the Gingery Lathe and Shaper. I gave the lathe away, but I kept the shaper as I never got it working quite right. I substituted a few things, changed a few of the castings, mostly to make them thicker, taller, and heavier.
I never finished with the modifications, but I did attempt to get the machine to cut it's own table. I was never able to get the thing to cut without chatter-and I mean a LOT of chatter. I had it driven by a treadmill motor, and eventually needed the belt to drive a different machine, so it's been in the back corner of the shop gathering dust.
I'll get some photos of it when I get a chance to pull it out, but it may be until after I finish with the Logan Lathe.
I suspect, however, that the chatter issue is caused by the front of the ram not being perfectly square and flat to the back of the toolhead, so the whole cutting load would appear on the 3/4" diameter cold-rolled pin that locates the toolhead.
Would this sound like a good place to start? I just noticed the gap (about 0.008") the other day when I was moving it.
