- Feb 8, 2014
- 11,151
An interesting collection of hardware. The Galil motion controller is an oldie, but it is an 8 axis! Easy to program using ''English like'' two letter commands.
The terms amplifier and drive can be used interchangeably....kind of. The amplifiers take an analog +/- 10V signal to operate the motor in torque or velocity mode. The digital drive may require some kind of a serial command signal, but may also accept an analog signal.
The Galil board and the amplifiers are fully compatible with each other. It looks like the Elcom motors are compatible with the amplifiers, need more specifications to be sure.
It may be possible to run the Moog motors from the amplifiers, depends on the specs and capabilities of the amplifiers. In other words, will they operate a brushed DC motor?
In that collection of stuff, you do not seem to have any drives for the stepper motors. The Galil board will run stepper drives also by moving a jumper. It can operate a combination of steppers and servos on a per axis basis depending on how you configure it.
The usefulness of the gearhead as a 4th axis would really depend on the amount of backlash in the gearing. Hanging an encoder on it would not be a difficult job.
It should be fun to play with all of this stuff.
