I'm working on a new workbench for my garage(workbench thread) and wanted to see if anyone had some input for wooden frame design.
Originally I was going to go with a steel frame under the heavy cast iron plates but money is low and steel is expensive.
Hence I've started thinking about making a wooden frame instead, I made a quick sketch of what I was thinking, using C24 classed 45x145mm lumber.
The frame will be 800 deep as the plates are, the granite plate is only 600 deep and will have a support beam infront of it.
The cast iron plates weigh around 200kg and the granite is 76kg more, so the empty frame needs to support around 480kg as is.
The biggest thing I can imagine putting on this table is the table from my metal mill, which is probably 150kg, so let's say 250kg for the sake of caution.
We're now talking nearly 750kg load on a wooden frame.
Does anyone have experience with a wooden frame holding up such heavy loads?
I felt optimistic about 500kg, maybe doubling up the timber etc but 750kg suddenly feels like a lot.
Would love to hear if anyone has tried anything similar!
