- Nov 28, 2016
- 2,496
I'll take a wild stab at it...
This piece...
...is intended to simulate a specific cartridge. The long rod is inserted through the barrel from the muzzle end, then the 'cartridge' is attached to the end of the rod. The bolt is reinstalled and closed on the 'cartridge', and the guage tells how much longer or shorter the headspace is than a standard or nominal length.
That's just a WAG, though...
Can you get some measurements on the 'cartridge' and compare them to known 7.62mm cartridge dimensions?
-Bear
This piece...
-Bear
