I have a missing gear on a starter motor, what I need to find out is the number of teeth and also the size of the blank from which to cut the gear. The gear that remains is an involute 20 deg. 38 tooth on a 1.578 in. outside diameter that is on a centre to centre with the missing gear CTC 1.069 in.
Any advice or help would be gratefully received. Thanks.
