- Feb 1, 2015
- 9,691
Sorry, I can't count today.What?![]()
![Face Slap :face slap: :face slap:](/styles/default/xenforo/smilies/face-slap.gif)
I used the temp solution today, and Murphy's law, of course it was going in Reverse, so I changed the wires, as you pointed out and all is working fine.If you wanted a temp solution:
Yep, now that I have it working, I see that it takes two switches, but that is all built into the more complicated switch.No, it's only to provide the on/off function and the reversing function all in one switch
Has nothing to do with the voltage
I'll start with that, as the first assumption when I start the process of figuring it out. Taxes need to be done first.I was going to mention: The switch is bilaterally symmetrical so all the cams should orient in the same way I would think
