I think you have something wrong. I hated abrasive because of the noise and especially the toxic dust. If I let the saw do the work it was NOT strenuous.
Wish i knew what i was doing wrong. I should have took a video of it. I tried using compressed air to cool down a little. Maybe the blade is clogged up but i dont have any cast iron to clean it up.
I’d try a new abrasive blade. Try just resting your hand on the handle when cutting, not pushing. Abrasive by its nature is the fastest saw so you don’t have to push hard, let it do the work.
I cant remember the thickness blade we used, they were supplied by work. Thinner cuts quicker but is more dangerous. You don’t want one of those blades to shatter. I was always worried about that, that’s why I didn’t push hard. I also didn’t keep even pressure, letting up like using the drill press.
