- Nov 28, 2016
- 2,393
I was attempting to chase down an oil leak on my 1919 Hendey tie bar lathe... I removed the guards from the gears on the end of the headstock and found that one of the gears has 6 broken teeth. Only half of each tooth is broken off, the other half of each is still there, so the gear works fine, but would not have the strength of undamaged teeth.
As I removed the guard, I found one of the broken pieces laying inside the guard. I'm not sure what caused the broken teeth.
I'm looking for opinions on how best to fix this... I have searched ebay and a few other sites looking for a replacement with no luck.
I'm considering attempting to build the broken teeth up with either weld or brazing, but I would be limited to trying to hand blend them back to shape, I don't have a setup to cut gears on my mill.
I've considered trying to find a shop that would make a new gear, but I know that will be pricey...
It is a 36 tooth, 14 DP gear (not sure on the pressure angle yet, probably 14 ½ degree) and is made of extremely hard steel. Anything that I do as a repair will be significantly softer, but I'm not really sure that it needs to be that hard...
I'm also looking at buying a dividing head...
I can't spend a lot on one right now, does anyone have any experience with the sub-$400 5 inch chinesium heads?
Advice is appreciated...
-Bear
-Bear
