Yup that would be even better but in a pinch not absolutely necessary.
Latinrascalrg1 Registered Registered Joined Dec 9, 2016 Messages 1,133 Sep 10, 2019 #11 Yup that would be even better but in a pinch not absolutely necessary.
N Nutfarmer Registered Registered Joined Aug 2, 2019 Messages 1,553 Sep 10, 2019 #12 Soft jaws bored out to fit the gears od would also work
H HarryJM Registered Registered Joined Mar 16, 2015 Messages 386 Sep 10, 2019 #13 Maybe a step collet might work. https://www.hobby-machinist.com/thr...p-collet-used-for-and-how-do-you-use-it.1564/
stupoty Active User Registered Joined Dec 2, 2012 Messages 1,733 Sep 10, 2019 #14 Pot chuck to hold a gear stupoty Apr 28, 2016 first time using a pot chuck to hold a part, cut the hole and hand pressed the gear in then... I made a pot chuck from aluminum to hold a gear by the edge for doing work on the center, worked well. the gear is pressed into it. Stuart
