Can anyone direct me to a documented source for dimensions, or maybe you have access to one to measure? I'm trying to figure out size suitability between their model 3 versus 4. They spec them generically as #3 = up to 12" swing and #4 = 12-15" swing. But I've also read posts where people get one on that swing basis only to discover their particular compound top surface is either to high or too low.
Specifically I think I'm after the distance between tool center & base notch like this pic red lines. I have 14" swing, but I'm almost thinking if I don't necessarily require the full radii swing, maybe opt for the smaller one. That way I can always make a spacer block to raise it, but more difficult to effectively lower the assembly if my compound happens to sit high. Any experience or comments?
http://www.traverscanada.com/radii-cutter-set/p/85-202-032/
![3-10-2016 0000.jpg 3-10-2016 0000.jpg](https://www.hobby-machinist.com/data/attachments/81/81658-dc697bea68c43edf1f34126df9bd3ace.jpg)
