I've been using this Teknomotor ER20 spindle on my project since starting out. It always got hot when running at lower RPM's and the way I had it mounted was pretty clumsy with a lot of hidden fasteners that made it difficult to put on and take off.
Several weeks back I was using it to enlarge a BXA toolholder and it overheated and stopped. This has happened before and I was able to let it cool down and use it again. Not this time....
I found this little Sherline upgrade spindle from GlockCNC. I bought a factory second with more runout than usual and some blemishes, I think I can live with it and if not I'll look into getting the taper ground. It's ISO 20.
I ordered one of these sewing machine servo motors from eBay, it should have enough power for my needs right now.
Counter-bored this block of aluminum I was already using so I can fasten from the front with locknuts.
Re-drilled this other piece so I could turn it 90 degrees.
Broke a cheap tap while getting the motor mounting situated, fortunately I had an easy workaround with drilling another spot and through bolting.
Decided to change to a metric fastener for attaching the two pieces of aluminum since I have a really nice 6mm bottoming tap.
Bolted up the spindle and motor mount.
Need to make some pulleys but I'm pretty happy with my day's work....
Thanks for looking.
John
