- Jun 7, 2013
- 10,135
To support the outer end of the tube, make a "spider", a disc of steel with 3 or 4 radial holes on it's periphery, tapped for square head setscrews, perhaps 3/8 NC, the disc will have a center hole facing the tailstock in its center, a pipe coupling of a size that its pipe size will fit through your spindle will be welded in the center of the backside and a piece of pipe screwed in; a cross hole is drilled through the pipe to locate the spider axially with regard to its necessary location inside the end of the workpiece. P pin is made to fit the crosshole, and it will bear against the end of the spindle, so the spider will not slide back into the tube against the pressure of the tailstock center. The setscrews are used to center the outer end of the workpiece similar to chuck jaws and allow safe facing and turning cuts or shallow boring cuts in the very end of the workpiece. If a shallow counterbore is made in the end of the tube in this manner, a steel disc can be inserted into the counterbore (fit tightly) so that when the part is turned around for boring from the other end, the chucking pressure will not distort the tube, and also it plugs that back end so that coolant is not thrown all over the place by the chuck jaws,
This method is especially good for making thin bushings from stock having enough length to allow the wastage of the counterbored part to machine off after the part is finished.
So far as the 7" length of the part is concerned, it will be necessary to cobble up some sort of steady rest. I have made them from steel plate machine burnt and machined up like a normal looking item, I have also made wooden patterns and had the cast in iron, which is the proper way to go about it. For smaller lathes it may not be necessary to make the rest hinged as most are; I just made one for my 9" Monarch lathe from the WW-1 era, A friend had an original, so I just copied it; it was made solid, no hinge, but with the front section open where the normal fastening point would be. For a small lathe it is not so important to have the hinge feature, and it is lots simpler to make.
