Hi I had a quick question about a multi zone heat pump install. When you pull a vacuum on several installed heads is the whole plumbing liquid and gas line under vacuum? Or should you pull vacuum on each service port? Reason I ask is I've seen pictures of the interior and the all the gas lines are all plumbed together. But the individual zones liquid lines are all actuated through valves so can't be under vacuum?? If I have this correct.
I'd like to put these under pressure with nitrogen to check for leaks for <3 hours. Then pull vacuum for possibly even much longer say overnight but can't be there for 2-3 days to do both zones.
