yep, just use a spanner wrench to take off the outter collar and the wheel will come off the adapter, not 100% about getting the adapter off but it appears that its the same as all the other grinders, you need a puller, you can make one on a lathe
Huh I posted this message like an hour ago it didn't show up
The puller I made is just a threaded piece that threads into the adapter, and has a threaded bar that you tighten against the spindle that will pop the adapter off the spindle very easy to make, you may have to thread your on the outside of the adapter unless it's threaded internally
