One way to change the color of your headers!
13 is too rich at idle. I remember when I was using the shop scanner in a previous life, the idle readings were closer to 14.5 to 14.8. Naturally at a higher power like full throttle under load 12.5 +/- half a ratio is safer to avoid detonation. Anyways I have no real advise as I stepped back to a QJet instead of going to a Sniper. I am used to the carb.
You will get it as others have.
Pierre
Pierre
