Ice Ball Press
rwm
Robert
Mar 25, 2013
4,749
OK. I am going to try to make an ice ball press. It has been done here with CNC.
I first needed to make a concave radius tool to machine a concave hemisphere into the stock. I can't use my regular radius turner because it need to be cantilevered to avoid contact with the stock.
Here is what I came up with:
4DCsbDkgfqiWi6yudiYzO-7DtEhCuEIUg5hdJ403lyyg0sw28JnXt3z_663ZpQ-7IArE4o-MznPQ74HFI=w1824-h1031-no.jpg
GeTT0KNnaBmyqcv-3T0S_7V50Wqx4EQPV4BtU2bWtC9Dz_mXLmE3QRvfsXGlFKYlatjwQx3LgJqgz-2Ir=w1824-h1031-no.jpg
p9CeNaucOaHM2CjJKtCae0pzPfIFY0lwiVAdNEhz4W8SQSASAZnaDjy4az0U9cn0Z7jB393g242fjj5MT=w1824-h1031-no.jpg
ORbHlmHJjE5DfjTNOGL3dlL1VpnBsFHRbOicnATeaup_My6iS29gsLJCNt5uJ7H15hrDU1lVXCCJhHYCP=w1824-h1031-no.jpg
As you can see, it works on smaller stock. I have to admit I was a little unclear on how to do the bearing. I have a large bearing face with the tool carrier disc resting on the cantilever. I used a 1/2" center hole with a brass bushing threaded 1/4 x 20 in the center. A 1/4 x 20 screw goes in from the bottom and nylock nut and washer hold the tool carrier down. There is a small amount of slop. Any better ideas?
The arm is a little flimsy and I may need to upgrade to 3/8".
More details when I get in some 4" round stock. The hemisphere will be just about 2.25"
R
  • 4DCsbDkgfqiWi6yudiYzO-7DtEhCuEIUg5hdJ403lyyg0sw28JnXt3z_663ZpQ-7IArE4o-MznPQ74HFI=w1824-h1031-no.jpg
  • GeTT0KNnaBmyqcv-3T0S_7V50Wqx4EQPV4BtU2bWtC9Dz_mXLmE3QRvfsXGlFKYlatjwQx3LgJqgz-2Ir=w1824-h1031-no.jpg
  • p9CeNaucOaHM2CjJKtCae0pzPfIFY0lwiVAdNEhz4W8SQSASAZnaDjy4az0U9cn0Z7jB393g242fjj5MT=w1824-h1031-no.jpg
  • ORbHlmHJjE5DfjTNOGL3dlL1VpnBsFHRbOicnATeaup_My6iS29gsLJCNt5uJ7H15hrDU1lVXCCJhHYCP=w1824-h1031-no.jpg
The first thing that struck me......I would cut worm gear teeth on the o.d. of your tool holder disc and add a screw and crank. By eliminating the handle, you could add a disc support over the rear of the disc.
Ahhh. A mini rotary table per se. Interesting idea. May be overkill though.
R
kddWaWQRj36k6v2x35Z62x1GBBp1Y6VXpi9baP1-P-EbcAzKR1Cc8TQ5o9fyPYEdhedo1xQbND7DeCpbxY=w584-h1031-no.jpg
That's awesome! I want to make one now. It's on the list.
I'd say that worked perfectly. Looks like a great surface finish too.
Thanks guys. Surface finish is good.
ArRW1AQTucC43PIKKR_roBy9ebt7LjH9ouRH0wKHl8mRmusyqitL6NRKLlfn1YAjpu-ZysctXRcL_dJxG=w1824-h1031-no.jpg
Next drilling long holes.....
R
All done except cleaning up a bit.
I drilled starter holes for the guides on a rotary table on the mill so they are dead on. I had to finish the 4" long holes with a hand drill but that worked great.
s6GRWpecsnMf5rrNce1QUveTGUa4TGxb4imlflQkVkXpqsTiCcuw4q-_ppB4w5rc0zSmf9ZsGHH_-uY_4=w1824-h1031-no.jpg
_Hh55bHoO7aeFyOwmaIHyb4nJFSKBHCRwETP3Y2h9tAkLmbSw1eddGso7koO4CiU1dBmIDLgmlXr2HxVkY=w584-h1031-no.jpg
Very smooth action.
KpC6PHvqmnSoXuYGP5boyWHTB8w7P6a-Lq5YDbdMvapLdlZ3FTyvilDxVdyJ0JQryDlMdjLo18zAGtW1pz=w584-h1031-no.jpg
CxZtR7DIyEFNfgpEGFHogZaDHpBgvDMBjRvYlENSD-jK1tqE7hoZvFWFdDL5jCmHsEFZheKW9ieX85VZ2=w1824-h1031-no.jpg
I will make a few with boiled water and see if I can get some perfectly round clear ones. This works very well. Makes an ice sphere in about 60 sec. Its amazing how fast it works. I used a pretty large mass of aluminum.
This one gets shipped out to a friend in Dallas but serial number 0002 is in process.
R
