Info On 16" Sb Please
Investigator
H-M Supporter - Gold Member
Jun 8, 2016
603
I need some information on this lathe I have been offered for sale.
Tag says swing is 16, bed is 6, catalog number is 117 C
Is this a taper attachment?
Gear box
rear view
Three belt drive on motor in under cabinet, flat belt drive on spindle. Motor is 2hp 3 phase.
Any information would be helpful. I know the people this belong to. The husband passed away in 2009, this is still in his shop garage where it was in use. It is covered in thick oil/dust that makes movement slow and stiff. The phase converter is gone so I can't run it to check it out. Paint looks very rough with chipping and peeling, but I saw very little if any rust, What looks like rust in the photos is the oil/dust sludge.
any info would be great, and any idea of value as well. It has a 3 jaw, drill chuck and live center for tail stock, various cutting bits, knurling tool.
It also comes with another lathe. If i take one I have to take both this and the 12" Logan turret lathe behind it.
Comments certainly welcome.
Being a single tumbler quick change gearbox it is most likely early 40's.
The spindle thread size is 2 3/8-6
Top spindle rpm's are about 900.
The headstock is a little long for gunsmith work but you can get around that.
Weight is around 1800
With the taper attachment and some tooling you'll have a nice machine. I really like mine.
I don't know much about the Logan but it looks good too.
As far as price goes it all depends on the area you live in.
One thing to note; that lathe has a power feed stop, or at least that's what it looks to be. Never seen one before, maybe an unusual accessory?
