I forgot to mention that (and it is probably obvious) the tool will be facing the back of the part if you thread in reverse from the inside coming out. the compound should be 29º to your left. 1/2 degree into the trailing edge.
Are you cutting a right hand or left hand thread? If you are cutting a right hand thread and the compound is set the same as an external thread your tool is cutting, or trying to cut, on the trailing edge. What's happening is the tool pressure is taking up the slack in your half nut and pushing your carriage forward.
Tom S
