- Nov 27, 2012
- 7,879
I wasn't going to document this as I'm sure there are plenty of posts on how to do so on the net. But what the heck, here it is my way, more like a refurbish since my intent was not to replace anything. Plenty of pics so beware....
First off, I'm a keyless chuck guy, they're what I prefer to use on the lathe & the mill, but there are times where I would like to use a keyed chuck. Knowing that Jacobs is now owned by the Apex group & has moved manufacturing off shore I set out to find me a nice used USA made Jacobs Ball Bearing chuck (I hear people have complaints about the non-USA made ones). Well I ended up with 3 of them, all for a total of $125 acquired at different times. Finally got around to working on them.
The ones I have are the ones that say "Made In the USA, Hartford Conn.". Then there are the ones that just say "Jacobs USA" on them & the ones that list a SVC Kit P/N on them. As I understand it the ones listing a service kit # on them are the offshore ones & the replacement parts do not interchange with the older USA made ones. Perhaps the internals might look different but disassembly/assembly should be the similar I would think.
Here are my chucks. Worst looking one in the middle, best condition one on the right.
![Img_0353.jpg Img_0353.jpg](https://www.hobby-machinist.com/data/attachments/131/131106-15587b9cc49fda6dc61e8fe5409deb26.jpg)
![Img_0357.jpg Img_0357.jpg](https://www.hobby-machinist.com/data/attachments/131/131108-d914afc25c26da0f71aaf0990b71872e.jpg)
Started with the worst looking one which was also the most filthiest internally.
![Img_0377.jpg Img_0377.jpg](https://www.hobby-machinist.com/data/attachments/131/131110-664d3ab20be6b7a8ffb63140e692d8de.jpg)
After cleaning.
![Img_0384.jpg Img_0384.jpg](https://www.hobby-machinist.com/data/attachments/131/131111-7bddeec6d14dfd3a6af313e7088b822f.jpg)
Well it turns out this one had way too much run out after reassembling it. I visually tested each one & I could have sworn this one didn't have that much runout when I got it even though the jaws condition did not look that great. I even tried switching jaw hole positions with no improvements. Ok, this one is going off to the side, I ordered some new jaws for it.
This is the rebuild instructions from Jacobs. They say to extend the jaws half way then press off the sleeve by pressing directly on the jaws. Now I don't know if this caused any damage to the jaws on the first one but I'm not taking anymore chances on the next ones.
on the next one I pressed the sleeve off with the jaws retracted just under the nose face but not fully retracted/bottomed out & had no issues at all by pressing on the nose. Finished that one & it came out very nice!
Ok, enough jibber jabber, on to refurbishing the last one which was the best looking one. Here it is....
You don't need to remove the arbor but it makes it easier to work on. Since I was replacing the arbors that came on them anyway I took them off first. I have the Jacobs wedges which didn't work on any my chucks. All 3 of my chucks already had through holes from the factory unlike the newer ones. Torched them slightly, let some Kroil seep in, & used a punch from the front to pop off the arbors.
First I pressed off the sleeve. Again, not wanting to press directly on the jaws, this time I found a suitable spacer in the scrap bin.
![Img_0400.jpg Img_0400.jpg](https://www.hobby-machinist.com/data/attachments/131/131112-3769acd95c7a0b8a825752885b49ac02.jpg)
Half way there.
![Img_0403.jpg Img_0403.jpg](https://www.hobby-machinist.com/data/attachments/131/131113-276b98a261f6d3fe39dcb34d085c900e.jpg)
Sleeve fully removed.
![Img_0405.jpg Img_0405.jpg](https://www.hobby-machinist.com/data/attachments/131/131114-82f210e3eec425cb6b940da37634a45f.jpg)
Be careful not to loose any ball bearings if you are reusing them. Here you can see the slot where they come out. This one barely had any grease if at all unlike the first 2. Almost looks like it only had oil.
![Img_0418.jpg Img_0418.jpg](https://www.hobby-machinist.com/data/attachments/131/131115-384612ef97c1fbc1e1b35ad72d3d2e76.jpg)
There are 32 3/16" ball bearings. Once they are all removed the jaw scroll halves/race & lower bearing race can be removed.
![Img_0424.jpg Img_0424.jpg](https://www.hobby-machinist.com/data/attachments/131/131116-91569803bcf16658c5d946f75a94539b.jpg)
Use your favorite purple or green cleaner to clean all the parts. In my case I'm not replacing anything, just removing & replacing the dried up grease.
![Img_0439.jpg Img_0439.jpg](https://www.hobby-machinist.com/data/attachments/131/131117-b10affa52e7a4796ad08784b280f78df.jpg)
I decided to give my chucks a polish to make them look purdy again.
![Img_0426.jpg Img_0426.jpg](https://www.hobby-machinist.com/data/attachments/131/131118-32f18cab09a0fb4d5d9a3ad775f0248c.jpg)
![Img_0429.jpg Img_0429.jpg](https://www.hobby-machinist.com/data/attachments/131/131119-deb8a0268652a0f48af8fdf4f38c4b54.jpg)
Ready to be reassembled but before that I demagnetized all the parts. I don't actually set the parts on the demagnetizer as shown below then turn it on, you should wave the parts across it.
![Img_0435.jpg Img_0435.jpg](https://www.hobby-machinist.com/data/attachments/131/131120-fd99a74d75b620f5411e1277b4a0786d.jpg)
Jacobs says to use a high quality grease but they don't recommend what kind. I was just going to use Super Lube but well I have Gleitmo 805 which is what Bison recommends to use in their chucks. Expensive stuff so it's got to be "high quality" right? Just for consistency I put the jaws back in the same holes they were removed from.
![Img_0442.jpg Img_0442.jpg](https://www.hobby-machinist.com/data/attachments/131/131121-979542b1e283ed39a1eac74666a20e0a.jpg)
EDIT: I made the mistake of lubing all the ball bearings with grease. Don't do that, still usable but they are stiff. Since then, I have taken them apart, cleaned all grease off the bearings, & just used oils on the balls. I only used grease on the scrolls.
![Img_0444.jpg Img_0444.jpg](https://www.hobby-machinist.com/data/attachments/131/131122-9df4667f9555644b700f8e645062a470.jpg)
Press the sleeve back on.
![Img_0447.jpg Img_0447.jpg](https://www.hobby-machinist.com/data/attachments/131/131123-d56564c4b45a4f5715192ffb45f62f7b.jpg)
![Img_0448.jpg Img_0448.jpg](https://www.hobby-machinist.com/data/attachments/131/131124-8df34c1cbbef5954a547e4ba212f5181.jpg)
But don't press the sleeve on too far so you'll be able to press it back off later if you need to service it again. Leave a lip, that's how they come from the factory. I suppose if you did go too far it can still be pressed back off.
![Img_0457.jpg Img_0457.jpg](https://www.hobby-machinist.com/data/attachments/131/131125-7e17fea0317c04a3f16f89e03c376ec9.jpg)
Here are the 2 completed ones. They're like brand new to me & will stay with me for a lifetime of use. Under .002" runout without replacing anything so I'm happy with that.
![Img_0459.jpg Img_0459.jpg](https://www.hobby-machinist.com/data/attachments/131/131126-42650549146629881aa4bcafca495c8f.jpg)
I'll update this thread when I get the new jaws & the results for the first chuck.
![Img_0353.jpg Img_0353.jpg](https://www.hobby-machinist.com/data/attachments/130/130822-15587b9cc49fda6dc61e8fe5409deb26.jpg)
![Img_0357.jpg Img_0357.jpg](https://www.hobby-machinist.com/data/attachments/130/130825-d914afc25c26da0f71aaf0990b71872e.jpg)
![Img_0377.jpg Img_0377.jpg](https://www.hobby-machinist.com/data/attachments/130/130827-664d3ab20be6b7a8ffb63140e692d8de.jpg)
![Img_0384.jpg Img_0384.jpg](https://www.hobby-machinist.com/data/attachments/130/130831-7bddeec6d14dfd3a6af313e7088b822f.jpg)
![Img_0400.jpg Img_0400.jpg](https://www.hobby-machinist.com/data/attachments/130/130834-3769acd95c7a0b8a825752885b49ac02.jpg)
![Img_0403.jpg Img_0403.jpg](https://www.hobby-machinist.com/data/attachments/130/130837-276b98a261f6d3fe39dcb34d085c900e.jpg)
![Img_0405.jpg Img_0405.jpg](https://www.hobby-machinist.com/data/attachments/130/130839-82f210e3eec425cb6b940da37634a45f.jpg)
![Img_0418.jpg Img_0418.jpg](https://www.hobby-machinist.com/data/attachments/130/130842-384612ef97c1fbc1e1b35ad72d3d2e76.jpg)
![Img_0424.jpg Img_0424.jpg](https://www.hobby-machinist.com/data/attachments/130/130844-91569803bcf16658c5d946f75a94539b.jpg)
![Img_0439.jpg Img_0439.jpg](https://www.hobby-machinist.com/data/attachments/130/130846-b10affa52e7a4796ad08784b280f78df.jpg)
![Img_0426.jpg Img_0426.jpg](https://www.hobby-machinist.com/data/attachments/130/130848-32f18cab09a0fb4d5d9a3ad775f0248c.jpg)
![Img_0429.jpg Img_0429.jpg](https://www.hobby-machinist.com/data/attachments/130/130851-deb8a0268652a0f48af8fdf4f38c4b54.jpg)
![Img_0435.jpg Img_0435.jpg](https://www.hobby-machinist.com/data/attachments/130/130854-fd99a74d75b620f5411e1277b4a0786d.jpg)
![Img_0442.jpg Img_0442.jpg](https://www.hobby-machinist.com/data/attachments/130/130857-979542b1e283ed39a1eac74666a20e0a.jpg)
![Img_0444.jpg Img_0444.jpg](https://www.hobby-machinist.com/data/attachments/130/130860-9df4667f9555644b700f8e645062a470.jpg)
![Img_0353.jpg Img_0353.jpg](https://www.hobby-machinist.com/data/attachments/130/130862-15587b9cc49fda6dc61e8fe5409deb26.jpg)
![Img_0357.jpg Img_0357.jpg](https://www.hobby-machinist.com/data/attachments/130/130864-d914afc25c26da0f71aaf0990b71872e.jpg)
![Img_0447.jpg Img_0447.jpg](https://www.hobby-machinist.com/data/attachments/130/130863-d56564c4b45a4f5715192ffb45f62f7b.jpg)
![Img_0377.jpg Img_0377.jpg](https://www.hobby-machinist.com/data/attachments/130/130866-664d3ab20be6b7a8ffb63140e692d8de.jpg)
![Img_0448.jpg Img_0448.jpg](https://www.hobby-machinist.com/data/attachments/130/130867-8df34c1cbbef5954a547e4ba212f5181.jpg)
![Img_0384.jpg Img_0384.jpg](https://www.hobby-machinist.com/data/attachments/130/130868-7bddeec6d14dfd3a6af313e7088b822f.jpg)
![Img_0457.jpg Img_0457.jpg](https://www.hobby-machinist.com/data/attachments/130/130869-7e17fea0317c04a3f16f89e03c376ec9.jpg)
![Img_0400.jpg Img_0400.jpg](https://www.hobby-machinist.com/data/attachments/130/130871-3769acd95c7a0b8a825752885b49ac02.jpg)
![Img_0459.jpg Img_0459.jpg](https://www.hobby-machinist.com/data/attachments/130/130872-42650549146629881aa4bcafca495c8f.jpg)
![Img_0403.jpg Img_0403.jpg](https://www.hobby-machinist.com/data/attachments/130/130873-276b98a261f6d3fe39dcb34d085c900e.jpg)
![Img_0405.jpg Img_0405.jpg](https://www.hobby-machinist.com/data/attachments/130/130875-82f210e3eec425cb6b940da37634a45f.jpg)
![Img_0418.jpg Img_0418.jpg](https://www.hobby-machinist.com/data/attachments/130/130877-384612ef97c1fbc1e1b35ad72d3d2e76.jpg)
![Img_0424.jpg Img_0424.jpg](https://www.hobby-machinist.com/data/attachments/130/130879-91569803bcf16658c5d946f75a94539b.jpg)
![Img_0439.jpg Img_0439.jpg](https://www.hobby-machinist.com/data/attachments/130/130880-b10affa52e7a4796ad08784b280f78df.jpg)
![Img_0426.jpg Img_0426.jpg](https://www.hobby-machinist.com/data/attachments/130/130882-32f18cab09a0fb4d5d9a3ad775f0248c.jpg)
![Img_0429.jpg Img_0429.jpg](https://www.hobby-machinist.com/data/attachments/130/130884-deb8a0268652a0f48af8fdf4f38c4b54.jpg)
![Img_0435.jpg Img_0435.jpg](https://www.hobby-machinist.com/data/attachments/130/130885-fd99a74d75b620f5411e1277b4a0786d.jpg)
![Img_0442.jpg Img_0442.jpg](https://www.hobby-machinist.com/data/attachments/130/130886-979542b1e283ed39a1eac74666a20e0a.jpg)
![Img_0444.jpg Img_0444.jpg](https://www.hobby-machinist.com/data/attachments/130/130888-9df4667f9555644b700f8e645062a470.jpg)
![Img_0447.jpg Img_0447.jpg](https://www.hobby-machinist.com/data/attachments/130/130890-d56564c4b45a4f5715192ffb45f62f7b.jpg)
![Img_0448.jpg Img_0448.jpg](https://www.hobby-machinist.com/data/attachments/130/130891-8df34c1cbbef5954a547e4ba212f5181.jpg)
![Img_0457.jpg Img_0457.jpg](https://www.hobby-machinist.com/data/attachments/130/130893-7e17fea0317c04a3f16f89e03c376ec9.jpg)
![Img_0459.jpg Img_0459.jpg](https://www.hobby-machinist.com/data/attachments/130/130896-42650549146629881aa4bcafca495c8f.jpg)
After cleaning.
Half way there.
