- Jul 30, 2017
- 477
Zambus carries them and has decent prices. You might want to get a higher rating as it makes wheeling easier, but these should do the job.
Carrymaster AC-300S Light & Medium Duty Stem Leveling Caster
Discover the CarryMaster AC-300S White or Black, a Light & Medium Duty Leveling Caster, part of the AC Series. With a net weight of only 1.32 lb, the CarryMaster AC-300S has a load capacity of 374.79 lbs per unit. The load capacity with 4 casters is 1102.31 lbs. The CarryMaster AC-300S White is...www.zambus.com
mJVail is also good (first site) but you’ll need to call them.
Those are the ones that I was going to put on the logan 1875 I was restoring. and will likely be the ones i use for this lathe... Thanks for reminding me...
Actually the AC-300 might be perfect, The use weight given is based on three casters in contact with the ground at any given time.. Per the manufacturers Info. Only thing I'm unsure of is you get less then half inch of travel to level the machine.. Ill have to check the floor area where it will be set and see if that will work.
As for being a good looking machine... YOU sir are way to kind, I bet you let everyone win board games at family reunions.
Thank you.
