How do you break an end mill? Just curious, as I've never done that.
Irrational Exuberance...
How else...
As an owner of the 727 myself, the most important thing I did was to add a DRO. I don't have the cash for a high dollar set up so I went with the Igaging scales. I have only installed them on the X and Y so far, as there is a quill mounted DRO included on the machine. So, for about $90, I have mine all set up. You will need to fab up some of the installation hardware, but that is what makes it so fun and rewarding when you start cranking those dials without having to count revolutions!!
I think you have a pretty good handle on the short term needs. Definitely get a set of parallels. You will need those pretty often, particularly when dealing with smaller parts. One thing I have found invaluable is a machinist square. They are pretty cheap and come in real handy when putting things in the vise that don't have square ends to sit on the ways of the vise.
As far as end mills, messing up a few is part of the learning curve. I started out with the full 20 piece HSS set that everybody sells. You can get them at Shars, Enco, Travers, Harbor Freight, etc. There are plenty of sellers on Ebay. I would get a set just to learn with. The best deal may be if you have a 20% off coupon at HF. You will find that you will use some sizes a lot, like 1/4, 3/8. and 1/2. You can buy a lot of individual end mills off Ebay as well. I am a big fan of cobalt end mills as they are inbetween the price points of cheap HSS and carbide, and they will stay sharp for a good while. Roughing end mills are your friend. They will allow you to make all of the nasty, hogging cuts with much less effort and strain on the machine, and at the same time allow you to avoid dulling those nice sharp finishing end mills. My personal favorites are the 3/8" and 1/2" M42 roughers that Shars sells individually on Ebay. The 3/8" is approx. $10 shipped and the 1/2" is about $13 shipped.
The one thing that you should keep a good supply of is cutting oil or some type of lube. I buy Oatey Dark Cutting Oil at Lowes hardware for $5. I probably go through a couple of those a month. If you ever mill without lube, your HSS and cobalt end mills will dull quickly.
The other thing is way oil for the ways and oil or grease for the lead screws. The one thing that I didn't like about my 727 is that the handwheels are fitted with ball oilers. I used oil for the first week or two. The problem is that the handwheel brackets are not sealed and the oil literally runs right out the bottom. I took mine apart and cleaned them well and then greased them up good with a Lithium based grease. No more worrying about creaking handwheels.
When you get ready to move the machine, put the head all the way down until the quill almost touches the table. I then put a block of wood under the bottom of the head housing and lifted it from there. The wood I uses was wide enough to spread the straps out and keep them off of the electrical connections running into the back of the electrical box.
If you use the metal base that comes with the machine, check it to be sure it is square and flat. I didn't pay attention to mine and it was off so much that the base of the mill was actually twisting and I was getting some lifting of the table at the travel limits. I was actually getting a slight bow in my cuts on large pieces until I figured that out. Also, I had to build a base for my stand that added 5 inches to the height. I am 5'11" and the factory height would have caused some serious back problems.
My next addition is going to be a rotary table with chuck and tail stock. Then of course I will have to get a coxial indicator to center the darned thing under the spindle...
And remember, pictures or it didn't happen!!
cleaning has to be done first
The smaller ones I have are all higher end axtrax and similar. They were bought for a mini cnc mill where the machine didn't have enough HP to overcome any dullness.
I've been watching craigslist for years. Atlanta is a really bad town for any types of machinest equipment in general. There was never any serious industry here, just a town of middle management. As a result you don't have the retired workers and discount old machines you get elsewhere.
Did find out that enco has 25% off and free shipping today only, about to hit them up. $30 for a Chinese dti vs 75 on sale for a mity make an easier choice
Sent from my D6708 using Tapatalk
