- Mar 26, 2014
- 1,519
Good day
I am changing the Primary range feed gear bearings on this machine, as well as a few other bearings. This gear is behind the feed and rapid traverse bracket. Do I need to remove this whole assembly? Or can I remove the rapid traverse clutch without removing this bracket. It shows a splined shaft and looks like it should pull straight out? That's how the feed drive gear and shaft come out.
Thanks for any direction
Cheers
Martin
