- Jan 7, 2016
- 3,320
I just started using Boelube and not in an MQL system, yet. However, if you go to their website here, there is a lot of information there, including the process for utilizing Boelube in MQL. Here is a tidbit copied and pasted from their website...Curious if you use Boelube just for tapping, or in an MQL system, or if you're using it as a flood coolant. I use a variety of coolant products depending on the stituation, but my system is MQL, so I prefer a coolant that is specifically designed for MQL such as the Unist Coolube 2210XP for steels or denatured alcohol for aluminum as described in the attached.
Manufactured from personal care ingredients, BOELUBE is biodegradable and dermal non-irritant.
BOELUBE is non-corrosive, non-flammable, chemically stable, and free of halogens, sulfur, phosphorus, silicone, petroleum and paraffin wax.
BOELUBE does not contain any ingredients considered a hazardous substance by OSHA, WHMIS, IARC, NTP and State Regulatory Lists. Refer to Safety Data Sheets for additional information.
BOELUBE will not promote dermatitis, provides a high degree of worker safety, and presents a safe effective method to machine various types of materials without special handling, fluid recycling, or typical disposal issues.
BOELUBE can be removed from surfaces using isopropyl alcohol, denatured alcohol, MEK, or aqueous cleaner.
BOELUBE has an indefinite shelf life.
BOELUBE is in most cases compatible with paints and sealants (though it is highly recommended that compatibility be determined before use).
BOELUBE provides superior lubrication when machining or forming the increasingly complex range of materials now being used in Aerospace and other manufacturing industries.
I used some of the liquid on my bandsaw over the weekend and I was quite impressed. The same goes for the paste I used while drilling a .625" hole through some 3/8" stock.
