you are welcome- anytime!Thanks Doc!
Right! I completely forgot about his site. Thanks!Dean's site has several engines of which a couple might be lathe only:
Taig Lathe Machining Projects
www.deansphotographica.com
Thanks, appreciate that tip. I'll do some research on them.A small wobbler can be built with only a lathe (plus either a drill press or some very careful hand drilling).
Thanks, another great tip!check out book 5 in the Workshop Practice series by Tubal Cain
"Milling operations in the lathe"
It should give you some ideas to get round not having a mill.
