    Dismiss Notice
Lathe Safety Thought...".
Discussion in 'SAFETY ISSUES & EQUIPMENT' started by The Liberal Arts Garage, Feb 22, 2015.
  1. The Liberal Arts Garage
    The Liberal Arts Garage United States Active User H-M Supporter-Premium
    102
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    Often I see pictures, usually electrical switches,which lead one to reach over the lathe to
    Operate them; Bad, Bad. Take the trouble to mount them at lower left hand height near the headstock. (close to where your hand is likely to be) ......BLJHB
  2. stupoty
    stupoty Active User Active Member
    206
    63
    City:
    London
    -Return to Top-
    My 9x20 had the controls mounted on the top near the back I always found it a slightly bad location.
    I've mounted my new lathe controls on the wall at the tail stock end (its in a corner side wall not back wall) as thats where i stand most when using it.
    Most vfd's can have more than one switch conected to the E stop input so you can mount multiple switches on bigger machines.
    Stuart
  3. Bill C.
    Bill C. United States Active User Active Member
    151
    63
    City:
    Clarksville
    State:
    Indiana
    -Return to Top-
    Same goes for milling machines too. If possible connect a emergency panic switch near the front of your machine. I've seen some that twist when pressed to the off position. Safety first
  4. The Liberal Arts Garage
    102
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    Just a little extra clarification-- if your right hand is tangled up in something, you are
    Probably still able to reach the switch with your left. A big red button? Go for it!
    BLJHB
  5. gears
    gears United States Swarf Registered Member
    0
    1
    City:
    Tallmadge
    State:
    Ohio
    -Return to Top-
    Just had a little girl get her hair caught in the mini-wood lathe doing a pen project - any ideas on safety? Policy is no loose hair - tie it up/back. Now I'm mandating hairnets. Ideas, thoughts?
  6. The Liberal Arts Garage
    102
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    i would only add a small lecture from a female machinist ( there's another important project! ........BLJHB.
Share This Page
