I have an LMS 5100 mini lathe. I'm noticing a patern on parts turned using power feed -- can't feel it but I can see it. The patern looks like a spiral drawn with a thin pencil. The spiral has a pitch of 16 TPI, the same as my lead screw. My assumption is that lead screw rotation is causing slight changes in tool pressure against the part being turned. Does that sound right?
And more important, what can I do to reduce or eliminate the issue?
Modifications to my lathe include using studs with nylocks to adjust the saddle in place of the socket head cap screws. I've no noticeable play with my saddle yet the carriage travels freely with no binding. I've also added compound slide gib locks to eliminate compound movement when not desired. Picture at https://www.snafu.org/other/2017-new-lathe/0502/p-171221710-0105.jpg
I do make sure that the half nuts are engages with the carriage as far to the right as possible before tightening the right lead screw bracket. That is about all I've done with respect to lead screw and half nut adjustments.
