The bolts for the feet to bed are 3/8"-16 x 1 1/4" long.
Those hinge pins are special. You are correct with your description. It could probably be made from a bolt. The nut, which goes on the inside, is a 5/16"-18. I can't get close enough to measure the pin end diameter but it since you have the bracket off you can measure the diameter of the hole. I'm assuming that end is larger, maybe 3/8" or 7/16" to form the shoulder. You are correct that there is a slot in the end opposite the threads so the nut can be tightened.
Hope that helps.
Steve
Hope that helps.
Steve
