Logan Belts
richz
Jan 19, 2012
181
Need some help with belts. Have a Logan 6560 S/N62241. When i got the lathe the variable speed pulley assm was siezed.
Took every thing apart and freed up. Measured the belts both 1" wide and ordered from a bearing house. I put in a new single phase motor and made a new motor pulley at work. I did not think about it at the time but the motor pulley was for an 1 3/16" belt. i started assembling this weekend and the upper pulley on the lathe is for a 1" belt and the motor pulley is for a 1 3/16". Could this be correct?
I e-mailed Scott. Set me straight on the correct part numbers and I have the wrong motor pulley. Excellent help.
Cool. Something to be said about american iron that is still supporting those old machines. You may get a pully form the guy parting out his 6560
